It is currently Thu Nov 26, 2026 7:34 pm
 Post subject: Early 8 1/4 ring gear
PostPosted: Mon Apr 19, 2004 9:28 am
I found a 65 Belvedere (slant w/3speed) in a yard this w/e. It had what appeared to be an 8 3/4 in it, but when I checked the gear it was a 741 case w/3.31 ratio. Will this bolt into my A-body housing? I had never heard of this unit.
PostPosted: Mon Apr 19, 2004 9:50 am
741 has a smaller (read weaker) pinion than the 489, but should work fine for you; still plenty strong for an A-body slant.
