It is currently Tue Nov 10, 2026 11:28 am
PostPosted: Sat Aug 19, 2017 6:45 am
Car Model: 1973 Dodge Dart 4-Door Custom Sedan
Hello All:
I have a '73 225 Slant Six and am wondering if anyone can help me identify what this inline fuse is for. As you can see from the picture, it's located just inboard of my brake cylinder.
Also, on occasion the car will not start in Park, but when I shift to Neutral, it starts right up. There seems to be no rhyme or reason for this, and it seems to occur without a pattern. (I know these two issues are unrelated).
Thanks!
Shawn
PostPosted: Sat Aug 19, 2017 8:29 am
Are you certain there is a fuse the there? It looks like a connector to me. And by the size of the wire it looks like the feed to/from the battery.
PostPosted: Sat Aug 19, 2017 9:02 am
Ditto what Josh said. Looks like the main power supply to the dash, fuse box, and ignition circuits.
PostPosted: Sat Aug 19, 2017 9:26 am
Total embarrassment . Yep, you guys are right.
Shawn
PostPosted: Sat Aug 19, 2017 10:36 am
That looks like someone replaced the fusible link with a fuse.
barracudadave67
66-B-Cuda S-6
67-B-Cuda 273 4bbl
69-B-Cuda 340 4 bbl
66-Dart project 273 2 bbl
PostPosted: Sat Aug 19, 2017 10:54 am
Nope, that isn't a fuse replacing a fusible link. My brother's 74 Duster has that same connector and I have seen many other mopar cars, trucks, and vans from the 70s and 80s that have that same connector on either or both the alternator feed to the battery or the battery feed to the fuse box/dash.
 Post subject: That other issue...
PostPosted: Sat Aug 19, 2017 11:03 am
That's the neutral safety switch at the driver's side rear above the tranny pan rail.... If your linkage is off just a bit the comb and detent in the switch may not make the correct contact and prevent you from starting the car, I've also seen it where the 3 prong plug was a bit loose not allowing proper contact.
PostPosted: Sat Aug 19, 2017 11:42 am
Thanks!
Shawn
PostPosted: Sat Aug 19, 2017 3:03 pm
Does the black wire's covering feel like it is made from silicone? If so, it is a fusible link. I have seen those connectors with fusible link wire and a blade terminal where it goes into the firewall connector. There is usually a 'flag' molded into the wire identifying it as a fuse wire, but they will break off over time.
PostPosted: Sat Aug 19, 2017 4:59 pm
If you follow the wire down it looks like the flag of the fusible link is on that wire.
PostPosted: Sat Aug 19, 2017 6:48 pm
You know what, I think you are right. I englarged the picture and now I see it.
