It is currently Mon Jun 15, 2026 3:39 am
 Post subject: Valve Springs 95 220
PostPosted: Wed Aug 23, 2017 3:10 am
I am getting a cam grind done at Clive Cams here in Australia and he has suggested a valve spring rate of 95 seated and 220 open or thereabouts .
Does anyone know of any brands with a rate close enough to this ?
Cheers,
DRIVE IT,DON'T HIDE IT
PostPosted: Wed Aug 23, 2017 3:39 am
Greg,
Can you post the cam specs?
It sounds like stock Mopar 340 V8 valve springs would drop right in and work for you.
PostPosted: Wed Aug 23, 2017 12:14 pm
Lou , I don't have the cam or cam card yet but he told me it is a 160 grind at 114 profile .
I guess the 160 is his part number for a specific grind .
It is to suit a supercharger running low PSI.
PostPosted: Wed Aug 23, 2017 12:33 pm
I found these 2 part numbers at Rock Auto
http://www.rockauto.com/en/moreinfo.php ... cc=1079647
http://www.rockauto.com/en/moreinfo.php ... 28&jsn=606
The pressures are close to what has been recommended , which one do you suggest ?
PostPosted: Wed Aug 23, 2017 4:03 pm
A valve spring for a boosted motor needs to be stiffer, then for a non boosted engine with similar cam specs. A 1.44 dia intake valve with 20 psi boost will have 32 lbs less effective seat pressure then the same spring with zero psi boost.
PostPosted: Wed Aug 23, 2017 4:18 pm
A 1.5 intake valve will have 35 lbs less effective seat pressure, at 20 lbs boost.
A 1.6 intake valve would be 40 lbs less at 20 lbs boost.
The larger the valve, and the more the boost, the greater on seat pressure is needed.
Just using some numbers to show effect. Find the area of the valve head, (radius squared, times pi (3.14)) minus area of the stem, times boost.
PostPosted: Wed Aug 23, 2017 5:07 pm
Well I'll be!!! I never thought of that but it makes perfect sense! Learn something new every day.
Rick
PostPosted: Thu Aug 24, 2017 12:27 pm
Thanks blokes , will see what i can come up with .
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
