It is currently Wed Jun 10, 2026 1:49 pm
 Post subject: holley 1920 won't idle
PostPosted: Fri Aug 25, 2017 4:18 am
hey. i can't get my holley one barrel to idle. it runs fine when it's not idling. what can it be?
PostPosted: Fri Aug 25, 2017 6:54 am
A vacuum leak:
Look for one between intake manifold to block, base of carburetor, power brake circuit if equipped, PVC hose, and any other vacuum driven devices that would allow additional air in to lean out mixture such as bad vacuum pods.
Crud in idle circuit in carb, and or incorrect float level.
PostPosted: Fri Aug 25, 2017 9:52 am
See here.
