It is currently Sat Jun 13, 2026 8:36 am
 Post subject: Oil Pan
PostPosted: Mon Nov 20, 2017 7:57 am
Car Model: Duster
I believe I need a new oil pan for a 71 Duster with a 225. We had a new rear main seal block cast after the last one cracked after being previously tap and died. Now when the pan is installed it is leaking, but we cant find a new one or a published match for this engine/car. Has anyone else run into this issue? Is there any other pans that will work?
 Post subject: Re: Oil Pan
PostPosted: Mon Nov 20, 2017 4:29 pm
The more common oil pan can be gotten from any 1967-1976 A-Body (Dart, Dart Sport, Demon, Duster, Valiant) with a slant six.
You also can use the oil pan from any F-body 1976-1980 Dodge Aspen or Plymouth Volare, but the oil drain plug will be in a different
position (but is still usable in an A-body without issues).
PostPosted: Mon Nov 20, 2017 4:40 pm
Is the aluminum seal holder what is leaking or is the rear main seal leaking? Sorry I'm not sure what is leaking.
Where are you located?
