It is currently Sat Jul 18, 2026 8:40 pm
 Post subject: slant belts
PostPosted: Mon Dec 11, 2017 5:23 pm
How do the belts run for alternator, air and power steering?
 Post subject: Re: slant belts
PostPosted: Mon Dec 11, 2017 6:28 pm
Clockwise from looking from the front. :P
Seriously, closest to the timing cover, is crank, A/C, and water pump
next out is crank, alternator, and water pump
front is crank, and power steering.
PostPosted: Mon Dec 11, 2017 7:03 pm
A guy gave me a motor with alternator air and power steering with no belts on it and only 2 pulleys on the crank How would that work?
PostPosted: Mon Dec 11, 2017 7:27 pm
Is the second pulley on the crank in front of or behind the harmonic balancer?
PostPosted: Mon Dec 11, 2017 7:42 pm
I think it is behind and their are 2 pulleys on the fan
PostPosted: Mon Dec 11, 2017 9:46 pm
Then it's missing the front pulley. The front and rear pulley bolt on to the crank vibration dampener with 3 bolts each. If you look closely at the crank pulley you should see 6 bolt holes - 3 of yours have bolts in, the other 3 don't
PostPosted: Tue Dec 12, 2017 4:54 am
That's correct. You got lucky that it's the front crank pulley you're missing. Easy to install, and fairly easy to find. Someone on here should be able to help you with one.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
