It is currently Thu Jul 16, 2026 11:46 pm
PostPosted: Fri Dec 22, 2017 5:08 am
Hi guys,
Has anyone recently tried to build a +0.085" or +0.104" Bore Engine Lately?
If so where are you getting Pistons?
THe Wiseco Catalog for 2018 only Lists +.025" and +.045" Pistons.
Whaddya think?
is it time for a group Buy to get some +.104's back on the shelves?
PostPosted: Fri Dec 22, 2017 5:20 am
I'm up for some "+.104" pistons if we can get them with thin racing rings.
-Matt
PostPosted: Fri Dec 22, 2017 1:25 pm
I decided to go with the .085's to have just a little more cylinder wall thickness and to allow me to bore to .104 in the future. Ryan did the same with his race motor. I think a group buy would be good. I'm not sure I can afford them right now since I just retired.
Rick
PostPosted: Fri Dec 22, 2017 7:30 pm
I got mine from Ross, but they are custom. Ross does nice work, but ask prices BEFORE you hit the buy button.
PostPosted: Sat Dec 23, 2017 4:11 am
Hi Dennis,
Can you say a little bit about why you went with Ross? I am looking at custom pistons for a new stroker motor. It will be a "Lou" motor, meaning I will drive it 1000s of miles on the street, make passes on the strip, and run some twisty stuff.
Thanks!
PostPosted: Sat Dec 23, 2017 4:20 am
How long ago did you order from ross Dennis?
And what bore size did you go with?
PostPosted: Sat Dec 23, 2017 8:49 am
Mine are +.100" flat top, thick deck forged nitrous pistons for a 6.7" rod with the pin moved down .100". It has a thin race ring package and a Slant wrist pin. On an uncut block they should be about -.080" in the hole and give roughly 9.5-1 compression.
It is a standard Chevy 3.5" blank and would have been $60 each, but for some reason they hit me $40 each for moving the pin.
They are absolutely beautiful all wrapped up in the box.
We used Ross because that was who Mike was using at the time. I am guessing I got them 10 years ago.
PostPosted: Sat Dec 23, 2017 8:52 am
Thanks much, Dennis! Every little bit of information helps...
PostPosted: Sat Dec 23, 2017 10:00 am
Does anyone have a current contact at Wiesco we could contact. I know Brian Nutter worked with Rob on the first round but he left there shortly after that. Seems like maybe he sent me a "Deptartment" or group within Wiesco to ask for after he left. That was on my old computer though and I will have to do some searching to see if I have it still.
Rick
PostPosted: Sat Dec 23, 2017 10:22 am
Sorry to divert the thread, but would anyone interested be in some 1.2" compression height pistons likely in 3.504" bore? I am thinking of getting 2 sets made for 198 crank + 170 block and stroker 225 projects I am working toward. Not right away, but down the road a little...
PostPosted: Sat Dec 23, 2017 10:41 am
What is the pin size Lou?
PostPosted: Sat Dec 23, 2017 10:45 am
Well I finally found something I saved for the future!!! :D :D This has some contacts if someone wants to check it out. This was from Brian Nutter.
Rick
Hello, effective March 4, 2014; I am no longer with Wiseco Piston.
Please refer all automotive related to inquiries to Nick D'Agostino's group (Sue Nash, Vic Ellinger, Keith Thompson, Jeff Clarkin).
For all forging related inquiries, please email Steve Legat @ Slegat@wiseco.com Followed up by Dwayne Snyder@DSnyder.com
For personal inquiries, I can be reached at BrianNutter72@gmail.com
PostPosted: Sat Dec 23, 2017 2:06 pm
I am likely going to use Slant 6 pin size, but I could switch to another size as I will need custom rods anyway.
Thanks for the Wiseco info, Rick!
PostPosted: Sat Dec 23, 2017 11:54 pm
If you go to a smaller pin like a Ford, you end up with a lighter pin, and a touch more room on the piston for the ring pack.
PostPosted: Sun Dec 24, 2017 5:01 am
Great, thanks for the advice, Dennis!
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
