It is currently Tue Apr 28, 2026 4:41 pm
 Post subject: back cut valves?
PostPosted: Sun Dec 24, 2017 7:24 am
Does anyone know if new, stock sized valves, are available back cut? Or should I just have the machine shop back cut my current valves?
 Post subject: Re: back cut valves?
PostPosted: Sun Dec 24, 2017 8:13 am
Mopar Performance had back cut stock valves decades ago, but are now in the dust bin of history. If I were doing a budget head and couldn't afford the bill for 12 valves and machining I would use new stock exhaust valves and a larger intake valve. New 318 valve springs will work for mild cams.
PostPosted: Sun Dec 24, 2017 10:04 am
I agree with Josh. If at all possible, get the 1.70 intakes at least if you are not big on cash. Is no one making the 1.70/1.44 valves inexpensively now?
PostPosted: Sun Dec 24, 2017 11:25 pm
www.sivalves.com/ is the only source I'm aware of for the 1.70", 1.44" valves.
The exhaust side flows well enough with a little detailing. The intake side needs the most help and hogging out the intake side for a bigger valve is cheaper than doing the same to the exhaust side with a new hard valve seat.
PostPosted: Mon Dec 25, 2017 5:42 am
The SI ones I got last year were less than $10 each.
PostPosted: Mon Dec 25, 2017 10:26 am
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
I had my head machined and rebuilt last year. The valves were less than 5 bucks each, I believe they are Ferrea's, 1.68 intake and 1.44 exhaust. If you need the details I can check with the machine shop after the holidays.
PostPosted: Mon Dec 25, 2017 11:55 am
Yes that would be good info to have. They may have a slightly larger intake available also?
Rick
PostPosted: Tue Dec 26, 2017 6:28 pm
I think one of my heads has 1.71 Ferreas in it. As far as back cutting, it's part of any real good valve job. It's just an ectra zngle that narrows the seat width on the valve.
