It is currently Sat Nov 14, 2026 12:01 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
 Post subject: Re: HEI conversion
PostPosted: Tue Jan 02, 2018 3:38 pm
Starts and then dies immediately? Where does the HEI module and coil get their battery voltage?
PostPosted: Tue Jan 02, 2018 4:34 pm
Car Model: 1968 Plymouth Barracuda slant 6 super six 4 speed.
They are getting juice from a single pole single pole relay which is being fed from the large alternator terminal. Switched source to operate the coil.
I'm human and I do things for the universe.
PostPosted: Tue Jan 02, 2018 4:49 pm
Where is the switched 12v source from?
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Tue Jan 02, 2018 5:12 pm
From the ignition switch, I jumpered off the terminals that used to go into the ballast resistor (which it's now bypassed). As soon as I turn the switch, the relay closes.
PostPosted: Tue Jan 02, 2018 6:35 pm
Did you try swapping the two wires that go from the module to the distributor?
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Tue Jan 02, 2018 6:45 pm
Yes sir, spark isn't any better.
PostPosted: Tue Jan 02, 2018 11:37 pm
Are you 100% sure the coil's primary (small) wires are the right way round? Wrong way round = engine will run but not very well and poor-quality spark.
PostPosted: Wed Jan 03, 2018 10:19 am
Yeah, there's + and - symbols on the coils pigtail port that I hooked on to, 12v from relay to coil and - to module.
PostPosted: Thu Jan 04, 2018 8:53 pm
Fixed!!! All this time it was a bad coil, oredered a new coil, now I got slight orange/ strong blue and white spark. What a relief! Thank you all so much for hard work and dedication for your fellow slant6'ers and country!!!
PostPosted: Fri Jan 05, 2018 6:21 am
Congrats! Nice to have that settled.
PostPosted: Sat Jan 06, 2018 4:28 am
Now you did go back and apologize to your lowly HEI module, right? :D :D We wouldn't want his feelings to be hurt! :D :D
Good to know the fix, congratulations!
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 2 guests
