It is currently Sun May 10, 2026 6:12 am
 Post subject: Piston dome cc"s
PostPosted: Mon Jan 15, 2018 3:00 pm
Has anyone measured the dome cc's of the OLD Jhans cast pistons? I measured using the .500 down the cyl method, and got 9 cc's. But that didn't seem like enough. So used modeling clay, and pushed the piston top into it. Then measured that, and got 15 cc's. That's a pretty big discrepency. I have a pretty bad cold, and my shop is pretty darn chilly, so not going out there for a few days, to do all this again.
 Post subject: Re: Piston dome cc"s
PostPosted: Mon Jan 15, 2018 3:27 pm
Car Model: 64 Valiant
Never done any Jahn's, but have done many, many other domed pistons. You only need to install the piston far enough down in the bore for the tallest part of the dome to be about .015" or .020" below the deck surface. And then calculate for that depth, it takes less solvent also most of the time. Very important to have the piston square in the bore with the flat deck area of the piston. If you have taken the piston in and out of the block, this can account for the discrepancy if you didn't resquare it as accurately as the time before. Also, on pistons that have a dome and valve reliefs, you often end up with a lower effective dome volume than you think you will because the reliefs take away almost as much volume as the dome adds to the equation.
Good luck.
PostPosted: Mon Jan 15, 2018 4:37 pm
I have done this many times in the distant past. I know I screwed up somewhere, and need to redo it. Just too cold to work out in the shop, right now. Just wondering if anyone of the old timers, remember about the Jahns pistons.
