It is currently Fri Nov 20, 2026 10:49 pm
PostPosted: Mon Nov 27, 2017 7:39 am
Hello. I am installing A/C on my 65 Dart GT. I am looking for recommendations and hopefully pictures as to where I should drill through the firewall. I bought the aftermarket kit that has the box that mounts under the center of the dash.
Thank you for your time.
PostPosted: Mon Nov 27, 2017 9:48 am
What kind of A/C setup are you putting in?
PostPosted: Mon Nov 27, 2017 10:17 am
Hello Dan. I purchased the Nostalgic Air Saden Kit. I'm using their supplied bracket.
PostPosted: Wed Jan 17, 2018 12:30 pm
Hello. Just checking to see if anyone has pictures or best location as to where to punch through the firewall for A/C line installation.
PostPosted: Wed Jan 17, 2018 4:42 pm
Contributor
My installation uses Vintage Air parts and behind the dash location, but maybe this article about my '64 Valiant installation will help a little.
http://www.slantsix.org/articles/vintag ... ge_Air.htm
PostPosted: Fri Jan 19, 2018 12:26 pm
Thank you. Yes, this is helpful. I am keeping the factory heater core, so mine will be a bit different. Perhaps I cut through in the location where this person has re-routed the heater hoses.
I have a Clifford valve cover and the engine is out getting built, so it seems like I can't go any further until I get the engine in. The last thing I want to do is drill holes and then find that the valve cover is in the way of my line fittings.
PostPosted: Fri Jan 19, 2018 5:59 pm
Here is a link to an install I did some years ago
http://www.forabodiesonly.com/mopar/thr ... tem.51820/
PostPosted: Wed Jan 31, 2018 12:15 pm
Thank you very much, Charlie. This is extremely helpful. I will be following this setup when I install mine.
Users browsing this forum: Ahrefs [Bot] and 5 guests
