It is currently Thu Jan 01, 2026 5:28 pm
PostPosted: Mon Feb 12, 2018 5:05 pm
Car Model: Slant Six M37
It seems like a great way to have both economy and airflow. They were installed on 318s so it would seem a well built 225 might do as well with one as a holley 390...
I have no actual experience with ether, I am just putting thoughts together that do not belong in the same room..
PostPosted: Mon Feb 12, 2018 5:45 pm
I haven't tried it, but I have always thought a Spreadbore carb should work nice on a warmed slant with some tuning required, but I was thinking Q-jet.
PostPosted: Mon Feb 12, 2018 6:19 pm
Frank Raso used to advocate the Q-jet, and there was a member who managed to carefully saw a Thermoquad in half and run it as a spreadbore two barrel. Somewhere I have pictures of that.
PostPosted: Mon Feb 12, 2018 6:20 pm
You'd have to get a Q-jet or Holey 4360 to bat in the 400-500 cfm range... the standard mopar T-quads are big and anything but a
built slant would be able to use the 700+ cfm big block units...
PostPosted: Mon Feb 12, 2018 7:32 pm
I'm happy with the Q-Jet on my car and I like it better than the AFB I had on it previously. I have it turned 90° like I had the AFB. It gets better fuel economy than the BBS too.
Quadrajet Upgrade
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
PostPosted: Tue Feb 13, 2018 10:36 am
Quadrajet Upgrade
Ok, I will become a student of the Q-jet..
Frank, which side do you have the primary's on, away from or towards the engine?
PostPosted: Wed Feb 14, 2018 10:06 am
Keep in mind that Quadrajet and Thermoquad carburetors are obsolete and tuning parts can sometimes be a challenge to acquire. Luckily for me, all I needed for tuning my Q-Jet was some primary jets.
I have my carb facing the driver-side fender. My reasoning for this this that the carburetor will operating for the vast majority of time with the secondaries closed and I wanted the primaries to be as equidistant as possible to all cylinders.
Write-ups here:
Quadrajet Conversion
Quadrajet Tuning
PostPosted: Wed Feb 14, 2018 12:04 pm
Found it!
TWO BARREL THERMO QUAD
PostPosted: Wed Feb 14, 2018 12:13 pm
Write-ups here:
Quadrajet Tuning
I overlooked the link you provided in your earlier post. Your write-up on tuning the quadra-jet is detailed and easy to follow. More than enough info here to get me in well over my head... Thank you!
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
