It is currently Thu Feb 27, 2025 1:17 am
PostPosted: Sun Jan 28, 2018 1:24 am
Thought I had it.
Does anyone have the Oregon Cam 2106R spec sheet you get from them when you get their cam?
Thanks
PostPosted: Mon Jan 29, 2018 10:35 am
I too have wondered about this cam grind and maybe a couple more I have seen referenced in posts that do not appear in the cam lobe sheets listed here in the forum. I have to assume these are grinds on file at OCG but not listed on their lobe reference sheet. Still would be nice to see the specs on some of them.
PostPosted: Mon Jan 29, 2018 6:16 pm
Car Model: 1974 W100; 72 Dart
Just sent my core to them. Will post my card when it comes back if no one beats me to it.
sb
PostPosted: Mon Jan 29, 2018 6:46 pm
sb
'preciate it.
PostPosted: Tue Jan 30, 2018 1:22 pm
Found this on another site:
#2106
210/214 @ .050”, 254/254 adv, .434”/.444” lift, 108 sep
I have to assume the 'R' means reverse the two lobe positions. Similar to the RV10.
PostPosted: Wed Feb 14, 2018 5:58 pm
Grind # 2106R
Lobe separation: 108 intake centerline: 104 Exh centerline: 112
Intake opens 3 BTDC closes 31 ABDC
Exhaust opens 37 BBDC closes -7ATDC
Dur 214/210 @ .050
Lift 444/434
Valve clearance: Int .015 Exh .015
-4* overlap @ .050"
That's all of them that are pertinent, I think.
sb
PostPosted: Wed Feb 14, 2018 7:05 pm
Looking for this:
https://onedrive.live.com/?cid=935E825B ... 39&o=OneUp
for the 2106R
PostPosted: Thu Feb 15, 2018 10:17 am
Maybe give Oregon Cam Grinding a call and see if they'll send you it?
PostPosted: Thu Feb 15, 2018 5:01 pm
I just posted everything from mine that I got in the mail yesterday.
Looking for this:
for the 2106R
What else do you need from it? PM your address, and I will mail you a copy of mine, if you like.
sb
PostPosted: Wed Jun 19, 2019 8:35 am
Just a little off topic, but what kind of idle does this cam have?
PostPosted: Wed Jun 19, 2019 11:18 am
Stock idle. Just a tiny bump up from stock 71-up cam.
PostPosted: Wed Jun 19, 2019 12:28 pm
Thanks! This is going in a pickup so I didn't really need it to lope. I just want it to pull a couple kayaks and a teardrop camper, and any bump over stock is welcome! Bonus points for good vacuum.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 19 guests
