It is currently Mon Apr 20, 2026 8:28 pm
PostPosted: Mon Feb 19, 2018 12:00 am
Anyone know the size of the O-ring seal on the end of the park lock cable for the 63 TorqueFlite?
I replaced the cable with a good used one two years ago, but I have a leak coming from somewhere and it's soaking the tailpipe in ATF. I suspect this O-ring, which I re-used from the original damaged cable. Probably time for a replacement.
PostPosted: Fri Feb 23, 2018 4:19 pm
Wow, no one knows the size? Gonna have to detach the cable from the housing to remove/replace the O-ring and was hoping to avoid doing that without having a spare ready to go....
PostPosted: Sat Feb 24, 2018 8:15 am
If you can't find the exact size beforehand, I'd suggest grabbing a small assortment like Dorman 80020. A local auto parts store should have this, or you can find it online.
Escape Velocity Racing
Users browsing this forum: Amazon [Bot] and 1 guest
