It is currently Thu Jan 01, 2026 5:36 am
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4
PostPosted: Fri Mar 02, 2018 8:31 am
RE: RODS
I always install one rod/piston assy, torque, and rotate.That way if there is a problem, I know where it is. Might be a stupid question, but the rod caps, are with the rods they came from, correct? Also installed the correct way (notch to notch).
PostPosted: Fri Mar 02, 2018 9:08 am
if using the OEM steel shim gasket. If using the felpro head gasket, install without using any sealer.
How come? I can't think of a reason not to use copper gasket spray on a composite head gasket.
PostPosted: Fri Mar 02, 2018 9:27 am
I guess you could, but why? These things seal great in any case and you are making your life simpler later with potential cleaning issues. I used spray copper on composition gaskets a few times, but haven't done it in about 20 yrs.
PostPosted: Fri Mar 02, 2018 10:29 am
I did years ago, but the newest felpro head gasket for the slant six, is a different type. It is slightly thinner, and more like a multi layer gasket, it has a coating, and a rubber type embosing at possible leak areas. Moreover Felpro says to install dry.
PostPosted: Fri Mar 02, 2018 11:54 am
Ah, I haven't used the new-type Fel-Pro gasket. If they say put it on dry, then…put it on dry!
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
