It is currently Sun Dec 28, 2025 6:30 pm
 Post subject: Oil pan plug leak
PostPosted: Sun Mar 18, 2018 11:11 pm
Car Model: 1970 D100
I have a small leak from around my oil pan plug which I don't want after a full engine rebuild. My plug only has a metal washer on it; is there supposed to be something else on it to help it seal?
If not, does anyone have any suggestions on fixing this slow drip?
 Post subject: Re: Oil pan plug leak
PostPosted: Mon Mar 19, 2018 9:15 am
Start with a good oil drain plug. The one to get is Chrysler part № 6034 376. It has a large, thick, built-in, rubber-covered washer/gasket and threads that fit properly.
PostPosted: Mon Mar 19, 2018 10:48 am
Do I have to go through Chrysler to get one?
PostPosted: Mon Mar 19, 2018 2:39 pm
No, you can click-and-buy here under its new part number, 6035 417.
