It is currently Sat Jun 20, 2026 9:51 am
PostPosted: Thu Mar 22, 2018 5:04 pm
New cam showed up today!!!
225 ci 1968 block, 1977 peanut head no EGR
Dimensions:
Bore 3.430"
Stroke 4.125"
Rod length 6.698"
Head volume 39 to 40cc
Vel Pro Head gasket dia 3.525"
Head Gasket thickness .039"-0.041"
Piston down in hole .180"
New cam Oregon grind # 346
rocker ratio 1.5
Lobe separation 108*
Lobe center line Int= 1048 Exh=112*
Cam lobe lift I= .317" E=.319
Lash I=.012" E=.012"
Cam timing at .050" tappet rise:
Intake open=13 BTDC Close= 41 ABDC
Exhaust open=46 Close=2
15* overlap at 0.050"
Lift at valve intake= .476" Exhaust=.479"
Static compression ratio = 9.6
One calculator gave 8.7:1 dynamic ratio Elevation= 300'
Second calculator gave 8.2 Using 10:1 static dynamic =8.5
If my engine actually has static compression 9.6 and dynamic 8.16, from what I recall from other posts here, it should run on pump gas with no problem, is that right?
PostPosted: Thu Mar 22, 2018 6:21 pm
You should be fine as long as your gears/convertor science is correct.
My Valaint with similar CR #s ran fine on 87...( 5 speed/ 3.55/ 24" tires)
PostPosted: Thu Mar 22, 2018 7:33 pm
I ran it on my favorite DCR calculator... you are fine... it will be closer to 8 DCR... it should run on pump gas just fine (some recurve fine tuning will
allow it to run on 87 vs. 89).
Looking like a nice torque band from 2k-4500 rpm from 229 peaking at 241 ft/lbs at 4K, around 196-216 hp peak at 5000 rpm... will be very positive
at street rpm vs. a stocker with a super six and very kind rear gearing.
PostPosted: Fri Mar 23, 2018 10:50 am
3.55 rear gear, 2600rpm stall converter, 24.5" tires Runs 60 mph @ 3000 rpm.
PostPosted: Fri Mar 23, 2018 1:50 pm
Nice to see all those numbers lining up.
