It is currently Mon Dec 22, 2025 12:03 pm
 Post subject: 10 inch brake question
PostPosted: Thu Mar 22, 2018 5:46 pm
72 duster 10 inch front brakes, small bolt pattern. Does any one know if 10 inch "B" body hub and drum could be put on the "A" body spindle to get big bolt pattern. I'm thinking, not.
PostPosted: Thu Mar 22, 2018 6:22 pm
I think the outer bearings are the same...
PostPosted: Thu Mar 22, 2018 8:49 pm
With the '73 and later big ball joint upper control arm, you can use the whole B body spindle and drum brake setup.
PostPosted: Fri Mar 23, 2018 7:42 am
No, the bearings (at least one) are different. I went through this with my '66 Barracuda. There is an AMC hub which uses the same bearings, but I wasn't able to find a seal. I ended up not using any of the original front brakes. I torched out the small upper ball joint and welded in a sleeve to accept the big ball joint and used late A-body drum spindles which are essentially B-body spindles.
PostPosted: Fri Mar 23, 2018 8:42 am
What do you consider "late" A body drum spindles? I thought the 72 "A" 10 spindles were the same up to when disc was standard.
PostPosted: Fri Mar 23, 2018 11:45 am
I'm 99.9% sure this will work.
'68-'70 B body spindle/brake assembly with a '73-'76 A body upper a-arm.
Slant Cecil
PostPosted: Fri Mar 23, 2018 2:48 pm
1972 model year is the last of the K-H disc brakes and small upper ball joints so 1973+ is "late". We had a disc brake equipped '72 Duster and I "enjoyed" rebuilding the calipers in 1998. I bought 5 pistons to replace pitted ones.
PostPosted: Fri Mar 23, 2018 5:06 pm
So, from what I am reading, it is not going to work, just putting "B" body 10 drums and hubs, on a 72 "A" body spindle
PostPosted: Sat Mar 24, 2018 11:04 am
Correct. Go look at the bearings used (rockauto.com) and you'll see why.
PostPosted: Sat Mar 24, 2018 1:47 pm
Thanks, that's what I thought, but I was asked by someone, and I didn't have the answer.
PostPosted: Mon May 14, 2018 8:28 am
First off, why stay with drum when you can get disc? Just bolt on a set of 73-76 spindles from a duster. they should bolt on directly.
No car info 3/27/2017 Guido
PostPosted: Mon May 14, 2018 2:22 pm
You have a set for free? The person that asked me, had some "B" body stuff on hand.
