It is currently Sun Nov 22, 2026 8:23 pm
PostPosted: Sun Apr 01, 2018 5:43 am
Hello Sages,
I took a vehicle out of storage and as I was running it discoverd a PS Leak.
I wanted to replace the Hoses - The Pressure Side Hose is listed and easy to find, but the Return hose is oddly not.
so I just need to confirm the tubing size of the return hose.
I think it's 3/8" but I just wanted to be sure before I order anything.
This would be on a 78 Dodge B Van.
PostPosted: Sun Apr 01, 2018 6:34 am
If I remember correctly That return hose is just a piece of 3/8 hose, that is held on the fitting with clamps. Just make sure you use Auto trans hose, not all hose is compatable with the fluid. Spec. S.A.E. J189 Return Hose
PostPosted: Sun Apr 01, 2018 10:29 am
x2... if you had the FSM for the vehicle, they sometimes list the length of the return hose in the steering section.
PostPosted: Mon Apr 02, 2018 8:14 am
Thanks Guys,
I was aware that the Hose was not any regular "heater" hose or "fuel" Hose.
I wanted to verify the Inside Diameter.
Thank you for the help!
I hope my leak is just due to expired return hose or clamps - since its on the van I need to remove the washer bottle to really inspect and check out whats going on there.
Cheers!
