It is currently Wed May 27, 2026 7:02 pm
PostPosted: Tue Apr 17, 2018 4:28 am
Car Model: 1946 Dodge 1/2 ton pickup
A guy over on the HAMB wants to know what trans plate this is. Thanks guys! part #1612346
PostPosted: Tue Apr 17, 2018 10:48 am
Looks like the adapter to install a small block 727 trans to the slant six engine. However the crank adapter is missing.
PostPosted: Tue Apr 17, 2018 1:33 pm
No Charlie it is a garage door adapter and it has the key hole to prove it. :D :D
PostPosted: Tue Apr 17, 2018 1:58 pm
Dang, you're right. How did I miss that?
PostPosted: Tue Apr 17, 2018 3:00 pm
That ain't no grudge door adaptor, it's a meatloaf adaptor!
PostPosted: Tue Apr 17, 2018 5:49 pm
Car Model: 1975 Dodge D100
Two Out of Three Ain't Bad.
PostPosted: Wed Apr 18, 2018 3:22 am
That does not look anything like the 727 to Slant 6 adapter plate I have. I would match it up to a Slant 6 block and an A-engine trans to see if it fits before I were to plan anything.
PostPosted: Wed Apr 18, 2018 4:04 am
Lou could be right. I was going by the starter location, and the two bolt holes that could be for the bellhousing to engine brace. I couldn't trace the part number. I know a swap meet Mopar vender that had a adapter, that I thought was for the slant,but was for a early V-8, can't remember which. I will try to call him, and ask.
PostPosted: Wed Apr 18, 2018 5:31 am
Starter bolt pattern looks much more Ford than Mopar to me, and even if it is a Chrysler item, that casting number is way too low to have anything to do with Slant-6s.
PostPosted: Wed Apr 18, 2018 6:13 am
I have been told the early Hemi (1950's) used this adapter, to use a torqueflite, or powerflite. Still have not found this part number, but 1612344 is for 55-56 some others, 241-330-331-354 hemi, and some non 318 poly engines.
PostPosted: Wed Apr 18, 2018 8:42 am
That sings, Charlie—starter pattern could be pre-Slant Chrysler.
PostPosted: Wed Apr 18, 2018 9:29 am
That may be a flathead piece. 251 Desoto to Simplimatic (or Problematic )
I might have one.....
PostPosted: Wed Apr 18, 2018 10:23 am
My money is on the application being Fluid Drive behind a flathead.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
