It is currently Wed Nov 11, 2026 1:56 am
PostPosted: Sat Apr 28, 2018 2:45 pm
Anyone know if any of the old cast iron adapter plates are still floating about?
What's this screw for?
'76 D100
PostPosted: Sat Apr 28, 2018 4:35 pm
Yeah they pop up from time to time, you can post an ad in parts wanted if you can't find one locally... you will need to make sure they have both the plate and
the crank hub adapter as well.
Depending on if someone has one of the 10 AREngineering aluminum units for the A-904/A-500 they will weigh less but are more spendy,
maybe they might part with one if they aren't using it, either.
FYI.
PostPosted: Sun Apr 29, 2018 11:26 am
Will do!
'76 D100
