It is currently Wed Jul 15, 2026 9:56 pm
 Post subject: Tubes in slicks...
PostPosted: Fri May 04, 2018 6:02 am
I'm sure neither the Challenger or Duster have tubes currently... Ordering the M/T slicks for the Duster (yes, my first time ever buying slicks :roll: ) and Summit sez I gotta have 'em!
Y'all runnin' tubes in yer slicks...?
 Post subject: Re: Tubes in slicks...
PostPosted: Fri May 04, 2018 8:49 am
You can run them. I don't.
Pressures may be more consistent, at the expense of more rotating weight.
PostPosted: Fri May 04, 2018 9:39 am
Aren't you supposed to put talcum powder in the tire for the slick and tube lubrication. At least with wrinkle wall slicks, I believe.
-Matt
PostPosted: Fri May 04, 2018 11:14 am
I have also heard that people use either baby powder or dish soap when they don't use tubes in order to help from leak down.
PostPosted: Fri May 04, 2018 11:34 am
My 23x10x13 inch slicks, leak thru the side wall, and there are no tubes available for them. I used Dawn dish soap on the inside. It helped, but didn't cure the problem. At least they don't go flat overnight. My 7x26x15 have tubes. Use talcum/baby powder, when using tubes. It lets the tube and tire slide, and prevents the tube from getting pinched.
PostPosted: Fri May 04, 2018 4:00 pm
Heavy high horsepower cars and stick cars like tubes. That pretty much leaves most of us out.
PostPosted: Fri May 04, 2018 4:11 pm
Interesting? But why is that? :?: :?:
PostPosted: Fri May 04, 2018 6:16 pm
Because they beat the crap out of the sidewalls, especially if it's a heavy car.
