It is currently Thu Apr 30, 2026 1:23 am
 Post subject: Carter carb
PostPosted: Mon May 21, 2018 10:20 am
Car Model: 1982 dodge ram
Will a 4198s Carter carb work on a 1982 Ram 150 LB delete with a standard transmission?
 Post subject: Re: Carter carb
PostPosted: Mon May 21, 2018 6:09 pm
4198s was after market service replacement carter carb for 1960 to 1965 225. Throttle linkage different on older carbs and no port for vacuum canister. So, not a good one for that application. got pictures?
PostPosted: Mon May 21, 2018 6:14 pm
No pictures! Thank you for answering my question.
Can you tell me what carter carbs will work?
