It is currently Mon Jun 22, 2026 11:54 am
 Post subject: 12v Electric wench?
PostPosted: Mon May 21, 2018 3:50 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
I have a 16 foot (Big Tex) trailer and I want to mount an electric wench so I can pull my car up on the trailer. How much wench do I really need. It's a 65 2dr sedan. Not sure what it weighs.
Since it's only pulling the car up a ramp I'm thinking I really don't need a monster wench but I don't want to under buy. I've been using a 2 ton hand wench and it's been working fine.
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
 Post subject: Re: 12v Electric wench?
PostPosted: Mon May 21, 2018 4:05 pm
I use this one. Got a pulley with a hook, to double line it. My ramps are short and steep. Winch handles it fine, and the wireless remote is a plus. I've actually used it to load a 4,000+ car, with no issues.
Don't forget the 20% off coupon.
https://www.harborfreight.com/2500-lb-a ... 61840.html
PostPosted: Mon May 21, 2018 5:18 pm
x2. that's the one that's popular with dune buggy, and hobbists here as well.
PostPosted: Mon May 21, 2018 5:25 pm
Watch for a HF sale.
I've seen that winch for $49.99. If it's not a coupon for $49.99, you can then apply the 20% off (sometimes there's 25%) coupon to the $49.99
HF also will have the snatch block (might even be on sale) for a double pull.
PostPosted: Mon May 21, 2018 8:28 pm
My electric wench just drives the car on the trailer.....
PostPosted: Mon May 21, 2018 8:34 pm
Winch. W-I-nch.
A wench is something completely different. Always makes me chuckle when I see ads for trucks with "a 2000 pound wench on the front bumper!" Of course, if you find yourself a wench that helps you load cars on trailers or can pull heavy loads, you know it is a keeper.
PostPosted: Mon May 21, 2018 9:35 pm
(Me thinks Sandy's got a keeper!) :D :D
PostPosted: Tue May 22, 2018 3:53 am
I got mine for about $49.00 a couple of years, ago. I usually, drive my car on the trailer, but the winch is nice to have if you have a problem, or need to load at the house, at 4 am.
PostPosted: Tue May 22, 2018 6:21 am
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
I have been contemplating adding a winch (not a wench, as mine is happy to watch vehicle loading procedures from the front seat, sipping coffee...) to my trailer. Probably a stupid question since several have said they use the HF 2500# model. Is this enough pulling power? I understand I can use a snatch block to double its capacity but I want something strong enough to pull my 3/4 ton diesel up the ramps if needed. Also, I was a little concerned about the small size of the cable on the lower rated units. Perhaps I'm overly concerned and/or overthinking this, but would like some feedback from real-world users before I pull the trigger on this.
 Post subject: Re: 12v Electric winch?
PostPosted: Tue May 22, 2018 7:41 am
The 2500 lb class of winches does fine for an A-body that rolls, but if you have a trailer heavy enough to support that Cummins Dodge then, yes, I would buy a bigger winch. 5k+ would be my preference.
PostPosted: Wed May 23, 2018 8:47 pm
Car Model: 63 Dart 81 D150
I used to use a 2500# winch to load cars on the trailer. I found it very under powered, even on a double pull. I now have an 8000# winch from Tractor Supply. I still use it in a double pull just to slow down the cable speed. You will never regret a bigger winch.
PostPosted: Thu May 24, 2018 4:50 am
I agree. Get the biggest winch, within your budget, and useage. In my case, it was just for occasional/emergency use, and I didn't have the money for a several hundred dollar item. If I were loading fairly large vehicles, on a regular basis, I would have purchased a larger, better quality unit.
PostPosted: Thu May 24, 2018 6:23 am
My wench is not electric. She runs on tacos, enchiladas, chips, salsa, cilantro, and guacamole. You got a good one.
PostPosted: Thu May 24, 2018 8:48 am
Which wench you talkin' about?
Or are you just winchin' around?
PostPosted: Tue May 29, 2018 7:28 am
Spelling (and punctuation) saves lives!
I'll be more careful how I ask the question next time. :shock:
It sounds like I won't regret getting a HD winch.
1965 Barracuda /6
