It is currently Thu May 28, 2026 9:12 am
 Post subject: Exhaust under oil pan
PostPosted: Wed May 23, 2018 12:54 pm
Car Model: 1938 Plymouth 4 dr. sedan
Thanks for the info about running my exhaust under my oil pan. I was actually surprised that it was a factory item. The diagram really helped, BUT, when I went to NAPA to see about the pipe it is no longer available. Part number 31307 by the pipe in the diagram is for the gasket. Any idea where I can get one of these reasonably. Prefer new too. I'm located in central Illinois. By the way, the diagram comes from NAPA's old exhaust "book" catalog, not on their computer.
Street rod an old car and then drive/use it. I'm a NSRA safety inspector if anyone ever wants that done to their car.
PostPosted: Wed May 23, 2018 1:16 pm
Find an old exhaust shop. They may have the card to bend you a new one.
PostPosted: Thu May 24, 2018 5:13 pm
Car Model: 63 Dart 81 D150
A "good" exhaust man can bend it without a "bend card". Find a good custom exhaust shop. I would tell you to bring it to where I work, but SC would be a bit of a drive for you. We would charge you somewhere between $100 and $150 for the pipe, installed.
PostPosted: Thu May 24, 2018 9:30 pm
Call Jeff Long in Paxton. 217/379-4415. He probably has the card for it.
 Post subject: Re: Exhaust Card
PostPosted: Fri May 25, 2018 4:45 am
The skilled Tech should refer to and use one of these for the build you require.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
