It is currently Thu Apr 30, 2026 10:59 pm
PostPosted: Sun Jun 03, 2018 7:33 am
Car Model: 80 Volare, turbo slant, 3300 lb , (The Squirl)
Can anyone tell me the differance between the throttle pressure and line presure adjustment screws in a A904? ( 1986) I am thinking throtle pressure is when it shifts and line pressure is working pressure to the valves and servoes?? Is this a correct analysis? And does higher line pressure mean higher throttle pressure is required to shift at the same rpm? And vice versa?
PostPosted: Sun Jun 03, 2018 8:22 am
Throttle pressure balances itself against the pressure regulated by the governor.
PostPosted: Sun Jun 03, 2018 12:08 pm
So
. If l adjust the govenor pressure or change the diff gears ( currently 2/45s ) that will change the govenor pressure hence changeing the rpm the trany will shift at.. at wot.
PostPosted: Tue Jun 05, 2018 10:23 am
Line pressure is set with an adjuster on the valve body. Throttle pressure is set with the kickdown linkage.
