It is currently Sun May 17, 2026 4:32 am
PostPosted: Wed Jun 20, 2018 12:27 pm
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Hey guys. I'm working on tuning my Valiant. It has a warmed up Slant with a newer Holley 390 (8007) and the Offy intake. I want to put a vacuum gauge in the car so I can tune it more effectively and see how the car does under driving conditions.
I've heard very mixed things about where to get the vacuum reading on the Slant. The Holley has a non-ported nipple at the base of the carb that pulls a pretty solid vacuum. I also have a bung on the #6 cylinder arm of the Offy I can tie into. I've heard good and bad things about pulling off either location, but haven't really found anything definitive. Any advice you could offer would be greatly appreciated.
Thanks!
Chuck and the Flying Valiant
PostPosted: Wed Jun 20, 2018 5:49 pm
Non-ported vac at the base of the carb, or even better there should be a 1/8 NPT port in the intake on the driver side face, just below the carb base. Get a hose nipple to NPT at the hardware store. #6 runner should be fine too, but maybe will fluctuate more.
PostPosted: Wed Jun 20, 2018 7:24 pm
I added a vacuum gauge when I re-newest the 83 D150.
Agree it is a helpful tuning tool. My set up draws vacuum from the tree at #6 intake port.
No issues with unexpectedly fluctuations.
I used standard rubber vacuum line, has been around 5 years and 30k miles and working fine.
PostPosted: Wed Jun 20, 2018 7:33 pm
On Holleys you want to use the port under the primary bowl... The reason for this is it sees what the carb will be
be directly sensing... and will have the direct bearing on your throttle plate position (which is important if the carb is not quite right
for your engine the readings can show if it's too big or too small), and will also help you directly determine what power valve to pick...
PostPosted: Fri Jun 22, 2018 10:57 am
Thanks! I figured that I could use that port but I wanted to be sure. If that doesn't work, I'll try Lou's thing with the bung, but I'd imagine it would be almost the same thing.
