It is currently Sun Nov 08, 2026 8:39 pm
PostPosted: Sat Jun 23, 2018 7:39 pm
Car Model: 1966 DodgeDart
I am going to do the HEI conversion on my 66 Dart Slant Six , Have all the parts on hand .
What confuses me is the connections on the FD 478 coil. It has 1 positive wire and 2 Negative wires.The terminals are marked+and-. How do I connect the relay to the positive side -just splice it in or pull the connector and add another wire?
I assume one wire on the negative side goes to C connection on the module and one wire connects to the negative from the coil. Am I not seeing things straight?What am I missing? I Prefer to use the relay ,but I read that it can run without it.
Thank You for your help in Advance.
Philip's66
1966 Dodge Dart 225
2005 Dodge Dakota 225
PostPosted: Sat Jun 23, 2018 9:01 pm
Please forgive me ,i was thinking too hard ,too long ,having a brain fart. :oops: found the answer I needed in GM HEI conversion troubles Post.
1966 Dodge Dart 225
