It is currently Sat May 02, 2026 2:25 am
 Post subject: Tdc question
PostPosted: Sun Jun 24, 2018 5:01 pm
Car Model: 1976 Dodge Dart Sedan
Hi folks,
Total rookie here rebuilding first engine in his life as I recover from cancer. I needed something fun and rewarding to keep me busy. I finally have enough energy to tackle this work. I sent the slant six off to machine shop and now it’s ready to go and I’m putting it together.
Question.... when I’m at tdc the pistons don’t actually come flush with the deck ... is this ok?
 Post subject: Re: Tdc question
PostPosted: Sun Jun 24, 2018 5:33 pm
Car Model: 1964 Dart 270
Yes it is normal for them to be below deck unless you built the engine specifically to be at the deck. TDC is just the highest point the pistons reach.
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
PostPosted: Sun Jun 24, 2018 6:55 pm
from the factory, a stock 225 slant with a piston at TDC, the piston will be .160 to .180
recessed. If you would measure the recession and cc a combustion chamber you could calculate the
engine's static compression ratio.
https://www.rbracing-rsr.com/compstaticcalc.html
