It is currently Thu Jul 16, 2026 5:20 am
 Post subject: Major thrust side?
PostPosted: Sun Jul 01, 2018 1:23 pm
Which side of our engine is the major thrust side? The lifter side?
 Post subject: Re: Major thrust side?
PostPosted: Sun Jul 01, 2018 2:53 pm
Car Model: 64 Valiant
The major thrust side is always in the leading direction of crank rotation, so in a standard clockwise rotation inline engine it is always the drivers side of the cylinder. In a standard rotation V engine, it is the lifter valley side of the cylinders on the passenger side and the spark plug side of the cylinders on the drivers side of the block. So if you are sonic checking a block, that will help determining if you need to offset bore the block to maximize wall thickness.
PostPosted: Sun Jul 01, 2018 5:30 pm
Thanks!
PostPosted: Mon Jul 02, 2018 4:34 am
Car Model: 1968 Barracuda - Fastback
CNC Dude, awesome answer! That's easy to remember.
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Mon Jul 02, 2018 7:33 am
No problem! Glad to help.
