It is currently Sun May 10, 2026 10:44 am
 Post subject: torsion bars
PostPosted: Sun May 02, 2004 8:29 pm
hi there.
my question is about torsion bars on my 79 aspen... i would like to drop a little my car, and i noted that the torsion bars have a big bolt to regulate it.
but.
if i low a little the torsion bars, the susp will be harder or i'll hit the road with my oil pan every time i brake?
gracias :)
Ñ sorry about my english, but in Chile we speak spanish... ¬¬.
PostPosted: Mon May 03, 2004 2:44 pm
You may be more likely to bottom out, but adjusting the height with the stock torsion bars does not have much effect on the ride stiffness.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon May 03, 2004 4:16 pm
Car Model: '23 T-bucket
Ummmmm, Matt? I beg to differ. That adjuster bolt regulates the spring rate, (aka: stiffness). One of the side effects is ride height. If one uses the adjusters to lower the ride height, it also reduces the "pre-load", and thus the spring rate.
If I'm wrong, I'll soon get corrected, but I feel very confident in my evaluation.
CVRO.....my suggestion is to find another Aspen or Volare, with a V-8 in it. Remove the torsion bars and install them into your slant-powered car. You'll then have a stiffer bar that will give you proper spring rate at a reduced ride height.
Roger
PostPosted: Mon May 03, 2004 7:46 pm
Roger
good idea... i'll try it.
PostPosted: Mon May 03, 2004 9:59 pm
Remember as a cost cutting measure in the final stages of the F-body recall mayhem (and learned from mistakes with 3-4 torsion bars then later 2 for the A-body)...F-body cars come with only one torsion bar type that is stock for /6's and both 318 and 360 V-8's... there is a 'stiffer' set
for the police, taxi and Station Wagon setups, but...the secret to this is they use steel or bronze bushings instead of rubber per a few other sources to stiffen up the ride....
PostPosted: Tue May 04, 2004 4:28 am
GTS, the only way you can change the spring rate of a torsion bar is to machine off some of its thickness, or make a significant change in the length of the control arms (A-body) or the bent end (F-body). Raising or lowering the suspension will change the angle a bit, which does effectively change some lengths, but the effect is minimal. The adjusting bolt is sort of comparable to putting a spacer underneath a coil spring - changes the effective height, but does nothing about the stiffness of the mechanism itself.
