It is currently Sat Sep 19, 2026 5:04 pm
 Post subject: 10 X 2.5:" brake ??
PostPosted: Mon Jul 23, 2018 1:01 pm
I have the 10 X 2.5" brakes on the back of the race car and I was wondering if anyone knows where to get a Metallic or semi metallic set of brake shoes in that size? All I see on Rock Auto is organic. Also looked under 85 truck listing to see if I could find something there and still no luck. Thanks for any help.
 Post subject: Re: 10 X 2.5:" brake ??
PostPosted: Mon Jul 23, 2018 1:25 pm
Maybe Dr. Diff can help you out?
http://www.doctordiff.com/
also if you have a shop around you that relines shoes maybe they can get you the linings you want.
PostPosted: Mon Jul 23, 2018 2:15 pm
Well, Firm Feel has them for $85 a set.
http://www.firmfeel.com/a_body_mopar_ca ... shoes.html
I haven't really looked, other than a quick Google search.
PostPosted: Mon Jul 23, 2018 2:29 pm
I just searched Summit and they have 1 set listed for an 85 Truck in 10 X 2.5" from Power Stop Auto Specialty Brakes for $18.99 Now I just need to verify 100% that that is the size I have. They came off of my truck when I swapped the bigger 11" brakes on to it in the Spring. I just can't remember for sure.
Thanks for the help!
PostPosted: Mon Jul 23, 2018 3:57 pm
http://brakeperformance.com/brake-drums ... -shoes.php
PostPosted: Mon Jul 23, 2018 4:29 pm
My Belvedere has 10 x 2.5" rear brakes. They are brake # 169 and this number fits most 60- 70 Mopars.
My 79 Volare also had the same size brakes and used the brake # 445. I think the biggest difference between the two is how the emergency brake hardware connects.
PostPosted: Mon Jul 23, 2018 5:56 pm
Are they bonded or riveted? (is there any riveted shoes anymore?)
It's possible to DIY riveted...…………...
PostPosted: Mon Jul 23, 2018 7:00 pm
Great info guys. Brake Performance even had semi-metallic shoes for my ancient 9".
