It is currently Sun May 03, 2026 1:17 am
 Post subject: How Much Oil ?
PostPosted: Sun Jul 29, 2018 11:21 am
I have a 225 1983 in a d150 truck .
I am confused as the manual says to use 6 quarts of oil and according to my dipstick it is showing it at being about a quart over
Could it be I have the wrong dipstick , or could it be that my engine only actually does take 5 quarts ?
Any suggestions or ideas would be greatly appreciated .
Thanks Steve
 Post subject: Re: How Much Oil ?
PostPosted: Sun Jul 29, 2018 11:40 am
My '84 225 w100 holds 5 quarts. My '85 360 d250 holds 6 quarts.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sun Jul 29, 2018 12:09 pm
My 85 holds 6 quarts.
PostPosted: Sun Jul 29, 2018 2:00 pm
Run it like the dipstick and see if things seem better or worse.
Ive had motors that loved to be a quart low.
Most hate to be over full.
PostPosted: Sun Jul 29, 2018 6:36 pm
Car Model: 1967 Dodge Dart 270
My 86 takes 6 quarts using the tall filter.
PostPosted: Sun Jul 29, 2018 6:51 pm
My 80 model holds 6.
PostPosted: Sun Jul 29, 2018 6:56 pm
My 83 D150 takes 6 quarts with a tall filter,
It seems that someone swapped in a non
truck dipstick into your D150,
If you want I will get a photo and measurements
of my D150 dipstick tomorrow and post here.
PostPosted: Mon Jul 30, 2018 6:25 pm
here are the measurements:
* tip to the stop at the handle 33 inches
* tip to the add mark 1 inch
* tip to the full mark 1 3/4 inch
part number stamped in the dip stick 3497030 M
PostPosted: Tue Jul 31, 2018 2:23 am
Thanks, John. I have only done one oil change on my 84 D-100, but I think it was only 5 qts with filter, to full mark on dipstick. I will double check.
PostPosted: Tue Jul 31, 2018 6:22 pm
I'm pretty sure they came both ways. Why, I don't know. Denny's 84 holds 5 I think.
PostPosted: Tue Jul 31, 2018 7:19 pm
For some of the D series truck run there was both a
D100 and a D150,,,
Maybe the 100 series was a lighter duty variant.
PostPosted: Tue Jul 31, 2018 8:22 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
My '82 D150 slant takes 6 qts. with a filter change. That's also what is listed in the '82 owners and service manuals. Unlike every other vehicle I have owned, the prescribed amount of oil comes in right at the full mark on the dipstick. Rather than overfilled. It seems like '81 through '83 D150's are all equipped the same. Not sure when Chrysler resurrected the D100 label again, but it might have been as early as '84 with Mexico production. The light trucks were all labeled D150's for a spell.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
