It is currently Sun May 24, 2026 4:54 am
 Post subject: Found these pistons
PostPosted: Tue Aug 07, 2018 4:24 am
Car Model: 1968 ve valiant
So was given these pistons- TRW L3012F and are 30 over, googled them as you do, did not find much?
 Post subject: Re: Found these pistons
PostPosted: Tue Aug 07, 2018 12:25 pm
That sounds like a Mopar 318 piston part number.
Measure across the head, it should be close to 4 inches. (3.938)
Were there 8 pistons in the set?
PostPosted: Tue Aug 07, 2018 12:41 pm
Good to see you on here doc. Hopefully the fires are not by your house.
PostPosted: Tue Aug 07, 2018 3:53 pm
Hey everbody, six pistons in the box, inside was a data chart, L-3012F is listed as 3.400" which is what i got, took somes pics, but need to find out how to link off google drive.
PostPosted: Tue Aug 07, 2018 5:11 pm
My bad, the TRW 318 piston is L3013F
As for the CA fires, those are 60 & 100 miles North of us at the moment.
PostPosted: Tue Aug 07, 2018 5:25 pm
you may want to mike the pistons to verify
but 3.400 is the OE stock size bore,
slants needing a rebuild typically need a .020 or .030 or more overbore
and over sized pistons/rings to match
you will need to find a NOS block or have a used block sleeved to use those pistons.
if they are not OS,,
don't trash em,,some folks like having old stuff around, or make bookends or trophies from them....
PostPosted: Tue Aug 07, 2018 5:43 pm
Cool.
60 miles is still too close for those fires. Best wishes that they get those contained soon.
Now back to piston talk.
PostPosted: Tue Aug 07, 2018 7:15 pm
You know i was just waiting for someone to reply with this, pistons are 30 over, but yes you are correct if they were L-3012F , but they are L-3012F-30.
PostPosted: Tue Aug 07, 2018 7:42 pm
Hey just out of interest, does the "F" stand for forged? Had a look on the net, some say yes and some say no?
PostPosted: Tue Aug 07, 2018 8:07 pm
In this case...…...No
I found my old TRW catalog
Pistons:
L prefix Alloy piston
100-400 series powergroove
500-1900 cast aluminum
2000 series with F suffix power forged
2000 series with CF suffix cast aluminum
3000 series with F suffix cast aluminum decompressed
F suffix pin fitted
CF suffix cast aluminum pin fitted
KF suffix piston and rings pin fitted
HF suffix hyperteutectic alloy pin fitted
PostPosted: Wed Aug 08, 2018 6:34 am
.030 over pistons would be useable, I would still have them checked for diameter so
you know exactly what you have
I know that the molten aluminum used to cast pistons is degassed,
I have never heard the term 'decompressed' used with cast aluminum pistons.
Is there any additional info in the TRW catalog concerning the 'cast aluminum decompressed'?
