It is currently Sat May 16, 2026 5:51 pm
PostPosted: Mon Aug 13, 2018 9:59 am
Car Model: 1962 Dodge Lancer
So, the junkyard engine had a bad crankshaft bearing. The auto parts store says there are several options, how do I know which size I need?
Thanks again and again!
PostPosted: Mon Aug 13, 2018 10:05 am
Car Model: Slant Six M37
Crankshaft main bearing or connecting rod bearing??
Both come in standard, and oversized (where the crank gets machined to renew the surfaces, and a larger (thicker) main or connecting rod bearing is used to fill the space..
More importantly at this moment WHY do you believe the crank needs new bearings... I ask because usually tho not always, that condition suggests there is more extensive work needed...
Pictures may help at this point, to identify a course of action that is required...
PostPosted: Mon Aug 13, 2018 10:15 am
One of nuts that held the bearing cap on came off, making it very loose, grinding off a side of the bearing. The nut was floating free in the oil pan.
The other bearings look ok.
[img]<a%20href="https://imgur.com/gRmvX6q"><img%20src="https://i.imgur.com/gRmvX6qm.jpg"%20title="source:%20imgur.com"%20/></a>[/img]
PostPosted: Mon Aug 13, 2018 10:16 am
PostPosted: Mon Aug 13, 2018 11:08 am
What does the crankshaft bearing journal surface look like? If the cap looks that bad you may need to have the crank ground.
PostPosted: Mon Aug 13, 2018 12:06 pm
That is a connecting rod bearing. Most likely you will need a new/different con rod, or at least get that one resized and have new bolts put in it. Do not skimp on this or you will not have a long living motor. Reed is right you need to carefully check the crank rod journal too.
PostPosted: Tue Aug 14, 2018 7:54 am
It looks like a later cast crankshaft bearing...
Is the oil spurt hole near the center of the bearing and is the bearing insert just under 1 inch wide?
Users browsing this forum: Google [Bot] and 10 guests
