It is currently Sat May 02, 2026 7:39 am
PostPosted: Thu Aug 16, 2018 5:08 pm
Car Model: 1966 Dodge Coronet Wagon
I have the small Thompson pump and would like to go to the more common Saginaw pump. Does anyone have a definitive way to do this? I’ve searched, but can’t really find a straight answer on what brackets etc I would need.
Thanks! Crispy
PostPosted: Fri Aug 17, 2018 9:24 am
You need the Saginaw pump and slant 6 brackets at a minimum. You may need to change the return fitting on your steering box to the one with a 3/8" tube and the pressure hose may or may not have to be custom.
PostPosted: Sat Aug 25, 2018 5:18 am
Yes, I’m having a problem finding the bracket I need for the Saginaw pump. Anyone have a source for this?
