It is currently Fri May 22, 2026 2:58 pm
 Post subject: Help! No Compression
PostPosted: Thu Sep 06, 2018 10:27 am
Car Model: 1964 Dart 225/A833 3.55 9:1 CR .473 lift 500AVS
I got my head redone and milled, put it back on and wont start i do a compression test and i have 0 compression i torqued the heads to 70 ft pounds new head gasket etc , i installed a new camshaft and timing gears as well everything lined up any ideas?
 Post subject: Re: Help! No Compression
PostPosted: Thu Sep 06, 2018 10:48 am
Did you adjust the valves? Timing chain on right?
PostPosted: Thu Sep 06, 2018 1:23 pm
Your correct i had to loosen up the lash and Boom i had 155 psi on very cylinder thanks! :roll:
PostPosted: Thu Sep 06, 2018 3:07 pm
:D :D
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
