It is currently Sat May 16, 2026 10:36 pm
PostPosted: Sun Sep 09, 2018 5:38 am
I’ve got a French friend who is piecing a Super Six together for his 73 Duster. Will his OEM cable work or will he need a longer/shorter cable?
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Sep 09, 2018 6:04 am
I can't imagine why the factory cable would not work. The super six in my 79 Volare was the same one as on the regular slant six engine. Where you will find problems is finding the correct kick down linkage for the trans.
PostPosted: Sun Sep 09, 2018 6:25 am
I told him his OEM throttle cable ought to work as he thinks the Super Six takes a different cable.
I believe he has everything except a “correct” throttle cable and a workingchoke setup. Thanks for chiming in!
PostPosted: Sun Sep 09, 2018 12:47 pm
My '72 Swinger uses the original throttle cable on a supersix setup. it just has a bit of a U shape to it. Works fine.
PostPosted: Mon Sep 10, 2018 5:15 am
Thanks!
PostPosted: Mon Sep 10, 2018 8:34 am
I'll loan this topic...
How about 65 Valiant with V8 pedal and super six? V8 cable is too long, will later a body cable fit?
PostPosted: Tue Sep 11, 2018 4:23 pm
Should bolt in and work fine.
~THOR~
