It is currently Sat Nov 21, 2026 3:41 pm
 Post subject: I need a new carb...
PostPosted: Sat Sep 29, 2018 10:07 am
Long time no chat,
I go out to check things and fire up the van and find the gaskets on the carb leaking again! It is about time for me to get rid of this POS 500 Holly.
What carburetor that I can get off of eBay that will bolt into this 500 Holly's place and be easy for me to deal with? I have no idea what would be a good one and at this point I definitely need something better than what's on here. I've been driving this thing now for how long and it still doesn't run that well. There's no choke on this one so buying a carburetor with a choke on it might be a new thing for me! LOL
I appreciate any suggestions as I'm sitting 23 miles from the nearest town and being able to purchase something on eBay and have it shipped here makes life a little easier.
Thanks,
Dan
 Post subject: Re: I need a new carb...
PostPosted: Sat Sep 29, 2018 6:43 pm
The Motorcraft 2100 is a direct bolt on if you have a Holley 350 cfm or 500 cfm two barrel. I had one on my D-100 about 10 years ago. Very simple carburetor.
PostPosted: Sun Sep 30, 2018 12:45 pm
Thanks...
PostPosted: Tue Oct 02, 2018 1:07 pm
If you want to unload that 500... lemme know. :twisted:
~THOR~
PostPosted: Wed Oct 03, 2018 8:32 am
Do you know which one I should get? They show models that fit certain motors and I have no idea which one to look at??
Thanks for the help...
Yes, I would definitely unload the old one...
PostPosted: Wed Oct 03, 2018 6:06 pm
The best one has "1.08" stamped inside a circle on the side. I used a 1.21 successfully, but it was jetted a tad rich. The 1.08 carbs were used by many Jeepers to get rid of the Carter BBD, because they perform better at angles than the BBD.
PostPosted: Tue Oct 09, 2018 2:15 pm
I am looking om eBay for one... don't know which one I should get...
PostPosted: Tue Oct 09, 2018 3:45 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 3971647025
Here is a 1.08" Venturi Model
~THOR~
PostPosted: Wed Oct 10, 2018 6:38 am
Make SURE you get one that has vacuum advance. I had a perfectly good NOS Motorcraft for a 260 that did not.
