It is currently Mon Oct 12, 2026 2:23 pm
 Post subject: No brake lights.
PostPosted: Mon Oct 29, 2018 1:43 pm
Car Model: '65/'69/'74/'75 Darts
1975 dart sport. I have no brake lights. Have power at the foot pedal switch, but still no lights. Any ideas? Could this be a problem with the infamous bulkhead plugs? HELP! :cry:
 Post subject: Re: No brake lights.
PostPosted: Mon Oct 29, 2018 5:37 pm
Car Model: '23 T-bucket
Could be, but do you have both, power in, and out, of the switch?
Checked the bulbs? Might be that both are blown for some reason.
Roger
PostPosted: Mon Oct 29, 2018 5:40 pm
Another problem area is the turn signal switch. The brake lights go through that.
PostPosted: Tue Oct 30, 2018 10:21 am
This summer, I had a problem with my stop lamp switch. The switch mechanism had come apart so the push rod had pulled out of the contact head. I put it back together with crazy glue and is again working properly.
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
PostPosted: Tue Oct 30, 2018 4:33 pm
Thanks for all the great tips. Turned out to be the turn signal switch. I managed to clean it up and get the brake lights working. I’ll order a new switch as soon as I can find one. :D
PostPosted: Tue Oct 30, 2018 4:56 pm
SlantSixDan has turn signal switches. Scroll all the way down to the bottom of the following page:
Daniel Stern Lighting - Products
PostPosted: Tue Oct 30, 2018 7:05 pm
Bought it. Thanks :D
