It is currently Fri Nov 20, 2026 5:21 pm
 Post subject: Yale Forklift
PostPosted: Mon Nov 05, 2018 6:25 pm
Car Model: Yale forklift
We have a 14K lb forklift with a Chrysler slant 6 on propane. We would like to switch it from propane to gasoline as it is used mostly outdoors. Would this conversion be as simple as removing the propane system and replacing it with a carburetor and accompanying fuel system? What else would we need to change or modify?
Thanks in advance!
 Post subject: Re: Yale Forklift
PostPosted: Tue Nov 06, 2018 7:37 am
We had such a forklift at the airport, and it was as simple as adding a fuel pump, carburetor, and distributor. The distributor on it had no advance and had points, so this is a good time for a HEI conversion if that's the case with yours. I don't remember how the carb linkage was hooked up though.
Users browsing this forum: Amazon [Bot] and 11 guests
