It is currently Tue Nov 10, 2026 3:46 am
PostPosted: Wed Oct 24, 2018 6:26 pm
Car Model: 1970 Dart Swinger ( mod top clone ) Slanty w/auto
Ok so what im going to TRY to do is take pics and let you guy know how ez or not it goes on ... as well as cover tuning ..
What i got is the Fitech 400hp EFI with the frame mounted pump and the return hose set up ... I think its kit # 31003
I all so got the fast fuel EZ EFI bracket and the Locar 24" throttle cable as well as there 904 kick down cable
All that coming to $1,281xx with CA tax :(
Any ? ask and i will try to give you answers.. This is my first time doing this so input is welcome
So here is a link to the unboxing pics ... the same link will as so have WIP pics as i go ...
http://s169.photobucket.com/user/ramcuda/slideshow/EFI
PostPosted: Tue Oct 30, 2018 5:09 pm
had a little time today to work on the injection ...
got the return fitting plumed into the tank ( little low i think )... SEE PIC ///
and did a but of fitting and some wire running mock up ..
and im going to be able to run the stock throttle cable .. SEE PIC..
https://beta.photobucket.com/u/ramcuda/ ... fc5c6fc15c
PostPosted: Wed Oct 31, 2018 3:01 pm
I've used FiTech before on a 455... it worked beautifully.
I look forward to seeing your results on the Slant. I have a 4 barrel Offenhauser manifold in the works which I plan to put a FiTech unit on for a blow-thru Turbo.
~THOR~
PostPosted: Sat Nov 03, 2018 12:46 pm
Hi all
Well all plumbed up and ready to hook up the 4 wires and turn the key ...
So things to note at this point ...
1.PLUMBING
jumping onto the stock fuel line and return lines speeds thing up and no worries of having rubber hose under the car to get tore up ... In the bay I found just bring the two lines up the fire wall and over the fan motor and running them across the back is nice looking and ez ,,,
2. TEMP SENDER
the temp sender .. the one supplied in the kit is a GM part and taping the stock port open fit it is not going to work ... instead we used the temp sender from a 2000 GM 5.7 .. its a 12m x 1.50 tp and is just a bit bigger than the stock Mopar temp sender..
TECH NOTE .... there is a upper limit ohm difference from the kit supplied sender " 82ohm " and the smaller sender " 88ohm" but dont worry about that ... FiTech has put out an soft ware update that will let you go in and adjust for the difference between the two ...
other than that i added some new pics of fuel line routing and stuff
PostPosted: Sun Nov 04, 2018 4:43 pm
ok its wired and runs ... the only thing id i cant get it to idle down to the 700rpm.. its stays about 800-840rpm... Tuning im sure
and i cant to get it to snap back to idle .. it takes a bit to come back down ...
I would say it good to start just tuning at this point ..
PostPosted: Mon Nov 05, 2018 11:59 am
If it won't idle down, make sure the blades are actually closing all the way. Since it has an IAC built in, the throttle blades don't need to be open far/at all. If you look at your display, it should indicate what % the IAC is being opened. You'll want to set the throttle blades such that you get between 7 to 10 % opening at idle. If it states zero %, try adjusting the blades.
~THOR~
PostPosted: Tue Nov 06, 2018 5:30 pm
thanks ill look at that ... is the fuel pump loud on yours ?
here a vid of mine ... so loud in face you cant hear the car much less you car hear it 10=feet away ... and there comes a part it ramps up and just stops when im driving and the car dies out
here the vid
https://www.dropbox.com/s/1sumfj00g2xwp ... 8.mp4?dl=0
https://www.dropbox.com/s/5vf3c67b365l9 ... 3.mp4?dl=0
PostPosted: Thu Nov 08, 2018 9:37 am
I ran the stock fuel pump into the surge tank with a high pressure pump taking it from there. Since the pump was in the surge tank, you couldn't hear it at all. The only noise I heard was normal induction noise through the IAC. I'll watch the videos here in a little bit.
~THOR~
PostPosted: Thu Nov 08, 2018 6:20 pm
Well new pump on its way from them ... out side of that im thinking about welding a bung into the bottom of the tank and finding a way of running the fuel line that does not get cough up in the rear end or shocks ... I can only get the idle down to 800rpm or so .. but at that my IACs are 0 to about 3or4 ..
But more tuning after the new pump gets in ..
PostPosted: Fri Nov 09, 2018 1:38 pm
I would try closing your throttle blades, until you get around 7 to 10 IAC. Does your TPS read 0% at idle? I'm trying to remember if FiTech has a TPS autoset feature as Holley HP EFI does.
~THOR~
PostPosted: Mon Nov 12, 2018 9:13 am
I put a fitech on my dart last year. Mine is a 318 though.
I had problems getting everything to tune but once I figured it out everything was good .
I have gone though 2 of the frame mounted fuel pumps. Both eventually started to leak at the fitting. The second one did it only at start up then stopped after a few drops but then the pump went out on me in less than 1,00 miles. If this third pump goes I am going to switch out to the in tank pump style.
I had the same issue with idling down. After getting frustrated with it I finally called Fi-tech. They had me rerun the software on the hand held controller, reset the parameters and then it would respond to idle changes.
Other tips that you have to find out on your own, not sure why they just don't warn you about it in the instructions.
1. Don't leave the hand held controller plugged in, it will kill your battery
2. You need to have a good reluctor in your distributor. Mine was chewed up a bit from use. Once I changed to a new distributor my idle was so smooth.
3. You have to make sure the blue pick up wire is away from any electrical interference, spark plug wires etc.
4. Finally while trying to figure out why the idle was messed up( see distributor issue above) Fitech said to use the MSD distributor. I tried it and it did not work. The system was not communicating properly with the distributor. Could be some sort of setting that had to be adjusted but fitech did not have a solution.
Definitely more power than the Edel 6oo
PostPosted: Sun Nov 25, 2018 1:43 pm
I have been contemplating putting a Go Street EFI 400HP System on a slant six, but, I am wondering about the value of having timing control like is available on the Holley systems. Can someone tell me if, for a daily driver, it is worth going to the additional effort of having timing control?
Thx
PostPosted: Mon Nov 26, 2018 10:16 am
Daily driver, non-turbo, I wouldn't worry too much about timing control beyond making sure the curve set in the distributor is appropriate for your engine setup.
~THOR~
PostPosted: Mon Nov 26, 2018 5:27 pm
Thanks for the feedback. I just took a look at the FiTech site and they seem to suggest that timing control is only useful with boost applications like nitrous or turbos etc. Am I correct?
"Ignition timing control allows the timing to be set to what the user desires with RPM and vacuum, without having to change springs, weights, or vacuum advance settings. It allows the timing with boost to be adjusted to be less than non-boost conditions. If a Power Adder system is used with timing control, the spark advance can be retarded when nitrous is used. There is an idle stability function to improve idle speed control by quickly advancing when the RPMs drop, and retarding when it jumps too high at idle. It allows the cranking spark advance to be lower than the idle spark advance, to keep the engine from kicking back on the starter."
PostPosted: Tue Nov 27, 2018 10:20 am
Correct. Based on their description, it would need to be a "locked out" distributor, which provides no mechanical or vacuum advance such as a "lean burn" distributor that has been used for many electronic control systems for our engines (MSD, Holley, etc.).
I wouldn't put any further worry into timing control.
~THOR~
