It is currently Sun Nov 29, 2026 5:16 am
Post new topic  Reply to topic  [ 924 posts ]  Go to page Previous 1 … 27 28 29 30 31 … 62 Next
PostPosted: Wed Nov 21, 2018 10:47 am
Dammit Rob, your almost making me think about putting the Daytona together. :?
ALMOST......... :mrgreen:
PostPosted: Wed Nov 21, 2018 11:35 am
:lol: :lol:
PostPosted: Wed Nov 21, 2018 7:48 pm
Oil and gear lube are in. I left the trans fill tube at the other garage.
I forgot about the alternator bracket bolt hole that leaks oil... :roll:
I made an angle bracket to help secure that side of the motor plate using that hole. The radiator support rod also goes through there.
PostPosted: Sun Nov 25, 2018 7:02 pm
I re-worked the main fuel line and re-mounted the fuel pump and fuel cell. I also cleaned and painted a trans fluid tube. I’ll put it in with a new O ring once the paint dries.
I also put the aluminum cross bar back in along with the fenders! :shock:
Getting closer. :D :D
PostPosted: Thu Nov 29, 2018 8:48 am
I've been sidetracked with a clutch job on Chase's SRT-4... I'll get back to the Challenger as soon as I can.
PostPosted: Sun Dec 16, 2018 2:56 pm
I carved out a couple hours today.
I fabricated new mounts for the 5 hood pins and reinstalled the front valence.
A little closer.
PostPosted: Sun Dec 16, 2018 3:58 pm
Woohoooo! :mrgreen:
PostPosted: Sun Dec 16, 2018 5:17 pm
Slow and steady wins the .........race or championship!! :D :D
PostPosted: Mon Dec 17, 2018 3:34 am
Hurray! I am hoping to get back to wrenchin in earnest in January. Taking a little break, except for gathering parts and getting machine work done...
PostPosted: Mon Dec 17, 2018 5:32 am
I need to finish things up and get over to Howard’s place so we can get it fired up. He gives me friendly nudges from time to time. :D
PostPosted: Mon Dec 17, 2018 4:55 pm
I put a pair of borrowed Chevy tires/wheels on the rear of the Challenger tonight, getting ready for the trip to Howard’s....
The new pinion seal leaks. :cry:
Very frustrating. Two steps forward, one step back...
PostPosted: Fri Jan 25, 2019 12:49 pm
Howard gave me another friendly nudge yesterday... I should be ready to take the Challenger to his place pretty soon. I may have to plan it around the bad weather since I don't have an enclosed trailer.
I just need to do a couple small things and then get a battery and some alcohol (for the car...)
PostPosted: Fri Jan 25, 2019 2:28 pm
Is the engine at Howard's? Final assembly there??
PostPosted: Sat Jan 26, 2019 1:44 am
I know where you can get a barrel of meth cheap. :mrgreen:
PostPosted: Sat Jan 26, 2019 6:37 am
While you are there don't forget my parts.
Thanks!
Send my thanks to howard..
Oh yeah and get 3 of your cars running!
