It is currently Fri Nov 20, 2026 1:04 am
 Post subject: Belt drive?
PostPosted: Wed Nov 21, 2018 5:25 pm
I saw an Aussie belt drive system on Facebook today. They are supposedly rare and run around $800. Are there any in the US? Have I been living under a rock? :oops:
 Post subject: Re: Belt drive?
PostPosted: Wed Nov 21, 2018 5:31 pm
Like a serpentine system ???
PostPosted: Wed Nov 21, 2018 6:39 pm
Cam belt Rick. I have since seen it is Argentinian.
PostPosted: Thu Nov 22, 2018 6:46 am
I've got a used standard cam hemi Jesel belt drive setup that I want to adapt to a slant. It does not look too hard to do, either cut the crank or build a thin spacer for the cam. It is way down the on the list of things I need to do.
Do you want to take on the project?
Mark
PostPosted: Thu Nov 22, 2018 7:35 am
Since the big block (and Hemi) crank sprocket and chain are the same as on the slant, I would think it shouldn't be too difficult to modify the cam sprocket to fit. Of course, I am sure it is easier said than done.....
PostPosted: Thu Nov 22, 2018 10:41 am
Are there any horsepower gains to be had there?
PostPosted: Thu Nov 22, 2018 3:04 pm
Jeff Droll used to make the spacer for the cam sprocket. Years ago he sent me the dimensions. I would bet Seymour still has them.
Isn't Hemi a 3 bolt cam?
Rick, it makes the timing very stable, but mainly it looks bad-ass. :mrgreen:
Mark, sounds like a good project for all my spare time. :oops:
Users browsing this forum: Amazon [Bot], Google [Bot] and 127 guests
