It is currently Sat Oct 24, 2026 7:43 am
PostPosted: Mon Jan 07, 2019 6:49 pm
Car Model: 1982 D150
Hi guys and gals,
Happy NEW YEAR TO ALL.
I am in need of help.
I currently had to change the distributor to my 1982 D150 225.
I turned in my non-functioning distributor as a core and forgot to remove the metal piece that's attached to it so that it can be bolted tight once adjusted.
I hope I'm describing it right.
No place seems to sell it.
Does anyone have an extra I can buy?
If not, what's my best option?
Thank you...
PostPosted: Mon Jan 07, 2019 9:05 pm
Was yours the one piece or the 2 piece? I should have some 1 piece ones down at my shop.
PostPosted: Mon Jan 07, 2019 9:23 pm
Not 100%. But I think 1 piece on distributor. And a claw to clamp it down that bolts to the engine block.
Slant power!!!
At least I try...
PostPosted: Tue Jan 08, 2019 11:39 am
If you have a claw, then you have the 2 piece, which is much nicer to use than the 1 piece most of us have.
~THOR~
PostPosted: Wed Jan 09, 2019 6:34 am
Thank you for the info.
So,,
Update:
I am in need of the piece that attaches to the distributor. I have the second part, I have the claw piece.
Can anyone please help?
Or can someone send me a picture of what it looks like so that I can fabricate something?
Please!!!
Slant power!!!
At least I try...
PostPosted: Wed Jan 09, 2019 7:26 am
Ok.. I found a picture of what I need.
Does anyone have one I can buy ??
Slant power!!!
At least I try...
PostPosted: Wed Jan 09, 2019 8:11 am
Sorry, I have no 2 piece hold downs to sell. :oops:
PostPosted: Wed Jan 09, 2019 11:35 am
Does anyone know the name of the piece I need.. maybe I can find it on eBay.
Slant power!!!
At least I try...
PostPosted: Wed Jan 09, 2019 1:11 pm
I would call it a distributor hold down ring, or a timing adjustment ring.
A quick search on eBag has netted zero results for just the ring. Plenty of claws everywhere.
Might try Wildcat Wrecking. I know they have a metric ton of slant distributors sitting around and I guarantee they have the part you need.
www.wildcatmopars.com
Talk to Vanessa.
~THOR~
PostPosted: Wed Jan 09, 2019 1:25 pm
Thank you very much for the info.
I really appreciate it.
Slant power!!!
At least I try...
PostPosted: Wed Jan 09, 2019 3:36 pm
Car Model: Toad Wagon
Looks pretty straight forward. Could a usable one be made from a one piece one?
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Jan 10, 2019 1:34 pm
With some creativity I don't see why not. Though in the grand scheme of things, they aren't expensive to buy from Wildcat or other Board members. Unless someone were feeling froggy, it seems logical to simply buy the ring and claw.
The claw doesn't have to be slant-specific; I'm sure there are many varieties out there which would work.
~THOR~
PostPosted: Thu Jan 10, 2019 2:12 pm
Car Model: 1967 Dodge Dart 270
I have one. PM me your address.
PostPosted: Fri Jan 11, 2019 12:35 pm
Now you guys know why I hit the $1 distributor bins at the swap meets. :D
PostPosted: Fri Jan 11, 2019 1:00 pm
When I ever get to a swap meet (rarely), I usually pour over all of the minuscule slant stuff and buy what is useful. :shock:
~THOR~
