It is currently Tue Nov 17, 2026 5:53 am
 Post subject: Carb I.D.
PostPosted: Sat Jan 26, 2019 9:28 pm
Car Model: 74 d100 64 d100
Trying to get ‘74 d100 up and running for daughter. I am having trouble getting the correct carb one of the screws has pulled out its treads. I ordered one it does not match what I have, looking for an I.D. I believe I have a 1920 and 1945
 Post subject: Re: Carb I.D.
PostPosted: Sun Jan 27, 2019 3:38 am
Looks like different years ,versions of 1945. What are the numbers on each carb ?
PostPosted: Sun Jan 27, 2019 7:16 am
3751425
6725
0294
Is stamped on the one I took out the new rebuild has already been returned
PostPosted: Sun Jan 27, 2019 7:43 am
I found a picture of a Holley h1 1945 the looks the same and mine. The choke lever on mine has a screw at the end so my choke cable connector can slide on. I just can not find any info on 1945 carb versions.....
PostPosted: Sun Jan 27, 2019 9:41 am
6725 is for 74 truck and stick shift trans California emissions
PostPosted: Sun Jan 27, 2019 3:49 pm
http://www.slantsix.org/forum/viewtopic.php?t=55801 info in this section
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot] and 4 guests
