It is currently Mon Nov 16, 2026 10:29 am
PostPosted: Fri Feb 08, 2019 3:51 pm
Car Model: Dodge W150
Thanks for all the helpful replies. My mechanic says timing mark is on, but I will double check. I believe the electronic distributor I purchased was to
fit a 1974 pickup. That shouldn't have egr should it? Just want to make sure I'm thinking right. That's why I figured it would be o.k. to get the egr valve
disconnected when I removed the lean burn? Thanks for all of the help!
