It is currently Wed May 20, 2026 12:38 am
PostPosted: Sun May 16, 2004 8:27 pm
Have a 69 Dart 225/904. Thinking of going to a 4 speed 833.
Better to take the engine/trans out? Or can it be done in the car?
No other reason to take the SL6 out, it runs great. But wondering
about the best way to do it when changing transmissions etc.
Seems like I recall it is easier to take an engine/automatic in or
out together, but a stick trans separated?
PostPosted: Mon May 17, 2004 6:24 am
I always do my trans conversions with engine still in the car, but you can do it the other way too...
PostPosted: Mon May 17, 2004 1:06 pm
lou- which way is easier, or at least which are the advantages or dis-adv.
of either.
PostPosted: Mon May 17, 2004 2:26 pm
of either.
I do tranny conversions with the engine still in the car, unless I have a new engine / trans combo to install as a set.
As for advantages, less stuff to disconnect when you leave the engine and just swap the gear box. The down side, hosting that 833 up into position can be hard if you do not have lot's of working room so get the car high up on jack stands to do this swap.
PostPosted: Mon May 17, 2004 5:59 pm
Car Model: 62 Lancer GT
I just did mine with the engine in. Worked out good. Like Doc said the more room the better under there.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
Users browsing this forum: Google [Bot] and 9 guests
