It is currently Thu Nov 19, 2026 11:36 pm
PostPosted: Sat Feb 23, 2019 5:11 pm
Should I stick with the A body cable which seems a bit long or would the K car cable (or is it the longer one) be long enough, even if I turn my 4 barrel sideways?
PostPosted: Sat Feb 23, 2019 7:58 pm
I used an Omni (L-body) cable and pedal when I turned an Eddy 500 sideways (primaries away from the engine).
It was long enough to avoid any sharp kinks and worked smoothly.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
