It is currently Wed Nov 11, 2026 8:26 pm
PostPosted: Wed Mar 06, 2019 11:59 am
Car Model: 1965 Dart Wagon
I am getting ready to do a slant six build and was trying to figure out if my engine has a forged or cast crank. It is right on the border of when they were changing over. Block code is 030-14 and stamping on other end of the block is 2775 which is what makes me think it’s a 75 engine. Block looks more like the later style than earlier to me, but I’ve read they were forged until mid 76. Is there a way to tell other than opening it up?
PostPosted: Wed Mar 06, 2019 1:14 pm
If only there were some sort of book that explained these sorts of things. Something that just covers the slant six would be ideal.
But, until you find one, look at the cast 'rib' on the outside of the block, driver side, behind the water pump. A thin, straight, horizontal rib indicates a cast crank engine.
If this rib is tapered (in thickness) it is a forged crank engine.
That sort of information should be in a book, maybe on page 20, but I am just dreaming...........
jus' sayin'
PostPosted: Wed Mar 06, 2019 1:28 pm
Thanks that’s exactly the info I needed. Mine is a cast crank, I was able to look up some pics online and see the difference.
PostPosted: Wed Mar 06, 2019 2:26 pm
Car Model: 1975 Dodge D100
jus' sayin'
:lol: :lol: :lol:
PostPosted: Wed Mar 06, 2019 3:27 pm
jus' sayin'
Lol!!.....
I don't have such a book, but if I did................. :D
PostPosted: Thu Mar 07, 2019 1:24 pm
[*]Image
(I had to...)
I did not have to post this image but this is cool and I want to make something like this out of all the old Mopar bumpers I have.
PostPosted: Fri Mar 08, 2019 6:33 pm
[*]Image
(I had to...)
I bought two! One for the library and one for the garage. Very detailed and well written!
PostPosted: Sat Mar 09, 2019 5:23 am
There used to be a guy here who ran around telling everyone they needed to used Ford pistons in just about any high performance engine because cast pistons would crack. I assume the same would apply to cranks.
PostPosted: Sat Mar 09, 2019 6:36 am
What he said.
PostPosted: Sat Mar 09, 2019 7:02 pm
I am assuming you meant forged? :lol: Anyway, it doesn't really matter. Cast cranks hold up pretty well on their own.
My good shortblock I got from Mike uses a light cast crank. The motor in the car now also is a cast cranker. :D
PostPosted: Sat Mar 09, 2019 7:10 pm
Well, he said Ford so who were we to correct him?
Then, there was the guy back in the 70's who thought those new 'Cadillac converters' allowed you to convert a Pontiac or Olds into a Caddy.
PostPosted: Sun Mar 10, 2019 10:46 am
The pistons in my good shortblock have a Ford pin diameter, and one of my heads has small block Ford valves in it, so there is that I guess. :mrgreen:
PostPosted: Sun Mar 10, 2019 11:21 am
That is not the first time I have heard of this. What is so great about the Ford pins? Are they lighter or something?
PostPosted: Sun Mar 10, 2019 4:27 pm
Smaller diameter and lighter. Smaller diameter can lead to being able to use a shorter, lighter piston.
PostPosted: Sun Mar 10, 2019 6:26 pm
I thought Ford pins were larger in diameter than those for a slant. I have them in one of my engines and I seem to remember that the rods had to be resized larger. There are more choices of thicknesses and lengths in Ford pins. I think Dennis's engine uses the pistons Mike used in my ill fated stroker motor and I think they had a .875" pin.
